Hi
I would like to add a wind generator to my existing photovoltaic system.
The inverter is an Italian branded version of the SOFAR HYD 3k-ES (Zucchetti HYD 3K-ES) and one of the two inputs is still free, as you can see from the picture below.
My idea is to use an auxiliary battery that fed the MPPT2 input through a Orion DC-DC converter. In this way I could easily monitor and measure the energy produced by the wind and would send any excess energy into the grid.
On the contrary, by connecting the wind generator directly to the main battery, I would have to add a monitoring system for the wind generator and I would not be able to feed any energy into the grid: If I have well understood, when the main battery is charged, the Victron Orion would stop itself.
At the moment I would like to understand if the described solution could cause problems or damages the inverter or the other components.
Thank you in advance for any help or any safe alternative
Best regards
Vincenzo Stefanazzi
Italy
Best regards
Vincenzo Stefanazzi
Italy
