I have a new solar system with a EG4 GridBoss and 2 EG4 FlexBoss. Before installing solar, I had already installed a Level 2 EV charging station inside the garage, connected to my panel. When the installers put the GridBoss + FlexBoss up, they left the EV charger where it was. I read that the GridBoss has four smart ports, one of which seems to be dedicated to EV charging.
Would it be better to move the connection from the inside panel to the GridBoss? What would the advantage be?
I just DIY installed a similar combo and decided to put my primary EVSE on a smart port. I just put the smart port in normal smart port mode and I like the flexibility. It was also more convenient wiring-wise (the EVSE conduit hits the Grid Boss before it hits the breaker panel that it used to be routed to). If the Grid Boss fails then I can just use my slow 120V backup EVSE until its fixed so no big deal.
I don't actually use any smart features beyond ensuring the port is turned off if grid-down. I don't want the high-power EVSE running at all in a grid-down situation. If I want to optimize charging or charge grid-down I just use the "slow" 120V EVSE off the BACKUP panel (aka uses inverter and battery and looks like a regular load)... which charges slowly enough that the battery buffers it quite nicely without having to worry too much. In anycase, that means the smart port is set to "Smart Load", "Smart Load Grid Always On", and everything else is turned off.
I find this works really well. I don't like too much "smart" logic messing up my assumptions about when or how much charging the car gets.
I also threw my AC coupled solar onto a smart port configured for AC coupling. Theoretically I could connect it to FlexBoss21's load terminals but again, it was just easier wrire-routing to use a smart port and I don't need black-start.
But because the Grid Boss can potentially fail, I don't put the main house sub-panel on a smart port... instead that is wired into the 200A panel connected to the Grid Boss's BACKUP terminals, so the Grid Boss's manual bypass works with it.
Another thing I would say is that even though the smart relays can kill a link while a car is charging, it puts wear on them when they disconnect under load and honestly I don't think its good for the vehicle either to have uncommanded power loss. So I would never actually try to use a smart port to manage EV charging. If the charge rate is too high such that it would cycle excessively, just reprogram your EVSE to charge at a slower rate or have a secondary "slow" 120V EVSE for those times.
-Matt
