Advice, building an off grid irrigation system, running a 1.5 HP pump from 12v or 24v?
Shawn Hayes
Learning Everyday
In A Southerly Direction
I’m planning an off grid, stand alone lawn sprinkler system. It should only operate two mornings a week for about 1 to 1.5 hrs BEFORE the sun rises.
Based on my sprinkler calculations I need a 1.5-hp pump operating on 115vac to satisfy water needs. A 1.5-hp pump uses about 19amps running. 19a * 115v = 2185 running watts, X 3 = 6555 watts starting surge. So my inverter needs to be sized to handle that.
Running watts should be: 2185w * 1.5 hrs = 3278 total watt hours each cycle it runs. (1.5 hrs twice a week)
Battery sizing using 280ah LiFePo4 cells:
12vdc at 280 ah is: 3584 watt hrs.
*Barely enough power
12vdc at 560ah is: 7168
24vdc at 280 ah is: 7168 watt hrs.
*More than double needed power
Plans to use 4- 100 watt panels and a 40 amp MPPT SCC to charge batteries. Then add an 12/24 vdc inverter to handle pump and sprinkler controller.
My question is; Does/Should the battery watt hours, be greater than the startup surge of the pump/system?
Could 12vdc handle that load even if I used a 12vdc 560ah diy battery?
Please check my math, I feel maybe I’m missing something? Any experience with off grid irrigation is helpful.
I see motor surges closer to 4-5X run. Did you measure this with an INRUSH meter, or is it calculated.
I had a 3/4hp pump that runs at 850W send a WZRELB 24V/2000W/4000W max inverter to overload-ville.
A soft starter may be needed.
Only if you get absolutely nothing from your PV that day... it's pretty rare.
See below.
Have you considered the idle power of the inverter? This is the one use case where the "ECO" mode might be workable if you manually run the pump.
~2kWh/day.
No, but the battery cells and BMS need to handle the run and surge currents.
Depends on BMS. Rather than ONE 12.8V 560Ah battery, I would build 2X 12.8V 280Ah battery each with its own BMS. If you have trouble with one, you still have the other to fall back on and two BMS give you more margin on start.
Helped my neighbor work out the inverter system needed for his 3hp 700' deep well pump, so I'm not a total dunce. :P
Calculated, as I do not have the pump yet but researching before buying.
Soft start devices was something I’ve considered but perhaps it’s a must have now.
Any recommendations?
See below.
I figure I will oversize the batteries to compensate. I’ve not settled on an inverter until I got feedback from the forum. However I will check idle draw specs.
~2kWh/day.
Agreed, that’s why I figured a diy LiFePo4 280ah battery with a JK BMS would be a safe bet.
Agreed. 2 X 12V 280ah each with JK BMS.
I was unsure if 12v would handle that, but X2 is better all around.
Helped my neighbor work out the inverter system needed for his 3hp 700' deep well pump, so I'm not a total dunce. :p
Thanks, glad I posted!!! I hesitated to ask for opinions on this. It seem pretty straightforward but felt I may be overlooking something.
Not an option. I’ve got two (3500 and 2500 gallon) rain collectors to gravity feed from.
This pump would work perfectly with a tank situated above it.
https://www.thesolarbiz.com/scb-24v-40p-booster-pump-scb8.html
They are ideal pumps for home pressure systems, sprinkler systems or in-line booster pumps. Like the SCS series, SunPumps SCB series pressure pumps are high-quality, maintenance-free, DC pumps specifically designed for water delivery in remote locations.
This 24 volt DC model is designed for battery direct operation
Pump curve
http://3415913.shop.netsuite.com/co...6yitCtZmTHjFZneIbeetoEmOtZKgxxkdRwAe&_xt=.pdf
Check out those motor watts on the second page of the pump curve PDF. Pretty tasty!
That saves making a bunch of AC amps with an inverter.
I would count on 5X. Soft starts tend can reduce this to about 30-40% of the 5X peak.
I would start with Micro-Air - the folks that make them primarily for RV A/C units, but they have units for up to 6 ton A/C units.
(y)
(y)
(y)
The process is very straightforward... the details are what kills you.
That pump I listed is a 2/3 HP, and only ~500 watts vs 2100 watts. Plus conversion losses and complexity. I think it makes up for the cost difference quickly.
@Rednecktek I would plumb in tees and ball valves, try the 1 pump and see. If not enough, put in the second pump and check valve off those tees and ball valves.
I will definitely looking into that. However, based on initial conversations with a company that does irrigation layouts and equipment. It seems the lift (elevation) needed, number of sprinkler heads and length of a couple zones, seemed to put most dc pumps out of consideration.
My intention was to use a normal rain bird controller to run the system. As well as a small pressure tank to shut off the pump automatically when system stops. Basically like a normal well tank/pump system.
