I want to set up a robust solar system for a vacation home in Baja. Looking to have a solar array of about 11kw (440 watt x 24 panels) with 30kwh battery (GSL 10kwh x 3). I was thinking that 2 mpp solar 6048s (or 6548)s) might be a good choice for all in one units to run all this. As I am not totally comfortable setting up a split phase system myself I want to hire someone down there to install it (while I watch and learn). I have a well respected/ recommended installer down there but he is reluctant to use Chinese all in one power units due to some bad experiences with pomcube system. He is suggesting an Outback Radian flexpower 8048 all in one but this is MUCH more expensive ($3k vs 8k). He is willing to install the mpp solar units but is “unenthusiastic” about having to go back and fix the mpp solar units if something goes wrong. I am thinking that at the Outback price point I could have 2-3 back up mpp solar units and still come out ahead. I would like to go the route of using the MPP solar units after seeing videos and Will’s recent video on installing essentially the same units that I want. He doesn’t seem to endorse sketchy products and I have seen other Youtubers report good results with the Mpp solar units as well. Obviously, being in Mexico makes repair/return a little more difficult but it would seem that installation will be about the same. I even have a Will’s video to show him!
Am I making a mistake here? Should I take the conservative approach and go with the Outback unit or take a chance with the Mpp solar units? (In case it’s not obvious, I am hoping you say the latter is okay ?).
