Ok. Been reading and designing a box that I can use in multiple vehicles. I didn't want to setup a dual battery on any of the other automobiles after setting up the first one. I am looking for any advice as well as any material you can send me to read. I appreciate both as I am learning but have little experiance in this area.
I have been reading what I can and watching a lot of videos. I had a friend help me with building my battery (he had done several) but admittedly has not done much in terms of wiring up multiple components like what I want to attempt. I have not put any of this together completely I have only powered on each compoennt and tested them to be sure they are working and have current firmware updates.
Ok.. on to the setup:
I have an 80 watt panel permanently attached to one vehicle and a 100 watt suitcase panel I swap between my other two vehicles. I do plan on installing 2 100 watt panels on my popup trailer. (in that case I would charge the battery while driving and then put the box and battery in the camper) If it needed charge I would depend on 200 Watt panels and a gas generator to charge using the shore power option.
I have not yet installed the battery cables in each vehicle, but Plan on attaching wires from battery to a DC 2 DC charger using anderson connectors.
I have also not yet build the box to put all the components in but my current wire lengths are close. I plan to fit it all into a 21 X21X 7 box with a couple of internal temp controlled fans to allow airflow.
I have been bargain shopping victron equipment for a while now so while its not all perfect size I think its close enough for my usage.
Items I am putting together in this build/box ** I did try to get good quality parts for this build.
- I know that electricity does not necessarily flow how I have the arrows drawn but I added them anyway for intent. :/
- I also know that this diagram is not super, I am limited on the software available for diagraming so this is best as I could do for now.
- I know just enough to know that I don't know enough. (which is why I am posting here)
- ** I have a home built 160 AH battery (will be separate from the box and connected with an appropriate 6' cable(s))
- Vicrton Smart 12 |12 -18 DC 2 DC charger (isolated)
- Victron Smart 100 | 20 MPPT
- Victron Smart 15 / 30 charger/powersupply
- VIctron 12 | 800 with bt dongle
- Blue Sea ST Blade Split Bus Fuse Block 30A / circut max 100 amp bus.
- all wiring is good copper welding cable or marine grade copper wires (as I have seen recommended here and on Will's site)
- all connectors are good qualtiy UL listed tinned copper or good ferrel connectors.
