Building my 1st portable 3-6kwh portable Solar battery generator! HELP!!!!! I'm prior Navy electronics tech. so know a little.
1)Just bought 2 Weize 100ah 12v lifepo4 batteries, ($399 ea on Amazon w/10 year warranty!) considering buying 2 more. BUT 1st, I need 2know if I can wire 1st 2batts.-in series & LATER add a 2nd set of 2batts.- in series to make 24v each pair (4-batts. total) THEN wire both pairs of batts. in parallel (2make 24vdc) to 24v input inverter. trying 2make 24 vdc system & don't want 2blow up bms's.
2)Can't find very many decently priced 24vdc solar inverters, for 5kw+ everything seems 2b 48vdc. HELP! Trying 2stay 24vdc system for portability & can't go 48vdc w/current build without 4-12vdc batts & stay in budget, only 2-12v to start.
Trying to get VERY min. 3kwh but want 5kwh & stay portable either w/dolly &/or box w/wheels or ? Have 2b able 2move easily.
3)Also are portable fold-able solar panels as efficient as regular static panels? Need at least 600+ watts in panel(s), (more for higher system kwh output), recommendations please for both panels & solar inverter, OR better 2go individual components? cheaper/more efficient?
Thank You!
4got2 mention need solar inverter output 120AC, (split phase 220 would be nice but limited budget) AND want FULL sine wave/clean solar inverter.
Thank You!
