I've been buying a few items and kinda been planning from what i read on various sites.
I have 2x 180Watt 72cell Solar panels - Optimum Operating Voltage (Vmp) 36.8V;Optimum Operating Current (Imp) 4.892A; Open-Circuit Voltage (Voc) 45.76V
I'll be linking them together in series. So i'm guessing it will push 75volts to 80volts maximum. I have an EPsolar 20A controller that i purchased the previous month, it's rated upto 100v input. Then i have 2x 12V 105ah Deep cycle battery's that i've kept charged every few weeks. <the 2x battery's will be running in 12v. as my inverter is a Pure Sine Wave 600w 12v DC to 230v AC>
This solar setup is made to be mobile. not roof mounted or fixed location, i'll place it in a sunny area (In South Africa, we get alot of sun)
1. Is my Controller maybe not big enough? The 2 panel input volts will be 70-80volt but less amps. Will it charge my battery to maximum of mppt power of 20amp?
2. Is 20amps enough for the 2x 105ah. I won't be running alot of power on it, maybe around 80-150watt for few hours at a time.
3. Is my panels not too much 360watts combined to charge a 12v setup of 2x 105ah? (so it will run as if it's 12v 210ah setup basically)
4. Due to it being a mobile setup, how do i ground it? Do i just take a negative wire and plonk a spike into the ground or does a mobile setup like mine not need grounding or to be earthed?
5. With my panels producing around 300watts of power & my utilization during the day not being more than 100-150watt. Can i run items during the day on "free power" Meaning. it will run my equipment and charge my battery's a little. <- In the case where my battery's is already full. Because my draw is only 100-150watt by my panels is charging panels @ 300w or more.
I've hinged the 2 panels together (to be suite-case style, to carry easily and put into the boot when traveling. (1250mm x 992m per panel). When camping i normally would use one 12v battery.
Any advice is welcomed.
In a nutshell this is how the setup will be linked :
2 Solar panels are hinged together like this - just as illustrated (except mine doesn't have the slide out stands etc. I still have to figure that out) :
