Gengfawn
I purchased a cabin 6 months ago that came with and off grid solar setup that is about 10 years old. I knew going in that it would need some upgrading but I just ran into some trouble with the inverter and cant decide the best way to move forward. I wasnt expecting this expense so soon so I'm not able to upgrade the entire system.
The power button on the inverter has stopped turning it off and on but I can still get it to start if I toggle the disconnect from the batteries a few times it seems to randomly start.
Im considering swapping the inverter for a cheaper model without a charger since the charge function is being performed using an external converter charger currently. I was wondering if it would make sense to replace the inverter with something like the Samlex PST-2000-24v.
The system is being used currently to power a 16 cu ft refrigerator that draws 7 amps, a 120 volt pump for fresh water that draws 1.5 amps, a tv that draws 2 amps, and about 6 led lights. I've included a picture that shows the layout of the system.
In the future I plan on replacing the batteries with a smaller bank of either 4 or 8 6volt gc batteries and possible replace the fridge with a smaller solar model that runs directly off dc.
Any advice on the best path forward that isn't a large expense right now but allows for replacement of parts or upgrading in the future is appreciated.
