Apologies in advance for the long winded post, but figure it best to include as much information as possible now rather than waste people's time having to ask questions later. Jump right to the end for the question.
Due solely to the great info in this forum In the space of a week I've gone from knowing absolutely nothing about solar/batteries etc to having the solution/plan below. Being well aware a little knowledge is a dangerous thing I was hoping that someone would be good enough to cast their eyes over it to make sure I am on the right track, before I pull the trigger and actually order something that may later prove to be a costly mistake. I've tried to include as much relevant info as I can think of below in advance.
PV Location
Roof 1: SE facing - 10.00m x 7.40m (74 SQM) - No shade
Roof 2: NW facing - 10.20m x 6.20m (63.24 SQM) - No shade
Yearly Average Sun Hours: 2.4 UK (Northern England)
Distance from house to array: 55m.
Electricity Usage
Summer avg daily usage: 8KWH
Autumn/Winter avg daily usage: 11KWH
Solar Spec
PV 60 x (JAM60S20 -380/MR/1000V) - 22800KW (Available, not to be fully used)
PMAX: 380W
VOC: 41.62V
LSC: 11.47A
PV Full Spec: https://www.jasolar.com//uploadfile/2020/1013/20201013031958494.pdf
Background
Last week I was chatting to a local farmer about wanting to go almost entirely off grid, but complaining that I did not have the roof space to do so. Surprisingly he very kindly offered to let me use his barn roof for a PV array or two completely free of charge.
Knowing absolutely nothing I naively jumped straight in with both feet and bought some PV. I stumbled across a good deal locally, but to get a good price I had to buy in bulk, meaning (I know now) I ended up with way more than I would need. I now have 60 x 380W JA Solar panels, just under 23KW. Massively overkill, but I figure it will give me the flexibility to size my array correctly and I can sell what I don't use individually for a small profit which will help fund the rest of the build.
For storage I have decided to go with a Seplos Mason DIY Box and 16 280AH EVE 14.3KWh 200A. Given my usage I hope that will be more than enough (please tell me if you don't think it will be). I'm planning to couple that with a Victron Energy MultiPlus-II 48V 5000VA 70A 50A.
The goal is to be off grid to an extent but still have the grid there to fall back on should I need it.
Question background
I would massively appreciate some guidance on the size of my PV array (or arrays), it's configuration and my MPPT controller (controllers) choice.
As my home is just under 55 metres away from the panels I'm aware I'll need to up the voltage to minimise losses. I'll also need to lay at minimum 16mm, preferably 25mm armoured cable. I'm planning to use 4 core to give me some flexibility.
Also being in a part of the UK which is not particularly sunny I figure I will need to over-panel, missing out on the peak energy created in summer but generating an adequate supply all year around.
My naive calculations have led me to believe that with 2.4 hours avg direct sunlight a day I'll need 9-12KW of solar panels to charge the battery and utilise while during daylight hours, as I work from home, and am in pretty much 24/7.
With this in mind I'm contemplating the following -:
6S4P
9120W
249.72V
45.88A
1 x Victron SmartSolar MPPT 250/100 - Cost (£900/$1072)
6S2P X 2
4560W (9120W Total)
249.72V
22.94A
2 x Victron SmartSolar MPPT 250/100 - Cost (£1800/$2150)
6S3P X 2
6840W (13680W Total)
249.72V
34.41A
2 x Victron SmartSolar MPPT 250/100 - Cost (£1800/ $2150)
or
8S3P
9120W
332.96V
34.41A
1 x Victron SmartSolar MPPT 450/200 (£2000/ $2375)
9S3P
10260W
374.58V
34.41A
10S3P
11400W
416.2V
34.41A
Finally my question
My question is firstly are my calculations correct regarding the amps and volts in my configurations, what size of an array would you recommend and based on that recommendation which MPPT controller(s) would you suggest I use?
I'm not tied to Victron, nor am I made of money. To be honest before I started I assumed it would be the panels that would make up the biggest cost. My budget was initially £5000/$6000, that's now doubled, so I'm more than open to any suggestions that can bring the costs down, regardless of the manufacturer.
Thanks very much in advance.
PV Location
Electricity Usage
Solar Spec
PMAX: 380W
VOC: 41.62V
LSC: 11.47A
Background
Question background
6S4P
9120W
249.72V
45.88A
6S2P X 2
4560W (9120W Total)
249.72V
22.94A
6S3P X 2
249.72V
34.41A
or
8S3P
9120W
332.96V
34.41A
9S3P
10260W
374.58V
34.41A
10S3P
11400W
416.2V
34.41A
Finally my question
