Hedges
I See Electromagnetic Fields!
- Mar 28, 2020
- 20,600
Sorry not sure what you are referring to?
My goal is to end up with a usable welded stud and attach the busbars some as you normally would, although I am leaning towards using a coupling nut instead of a standard nut that way it uses all available threads vs just a couple above the bus bar and balance leads.
Gotcha.
Coupling nut because it is longer, sounds good.
I thought you meant coupling nut to make a female thread, busbar on top of that, which would have been poor electrical path.
Make sure cable connections are limber enough that cable doesn't loosen its nut.
People here have assembled and used batteries with tapped holes, welded, studs, others, but all seem to be an aftermarket kludge which was done to make EV reject cells marketable to the solar storage market. Many tales of stripped, pulled off, etc.
And then some have poor contact, hot busbars and apparent voltage deviation of cells. Make sure you deal with native oxide and use some sort of corrosion inhibitor.
A few newer welded terminals look more robust.
One guy got himself a bank of cells with welded busbars between them (as replacement system, after catastrophic failure.)
