Dadoftheturkeykids
Arc Angel
Ok, quick recap.. So I have been running this setup for over a year now, with zero issues.
(See picture)
The only thing that has changed, is I have a class-T on the positive inverter lead instead of that junk black breaker
(bottom-left)
I want to "tidy-up" my battery wiring, as to...
1)Have batteries in normal orientation instead of standing on-end
2) make all cabling equal lengths on my paralell configuration(battery-interconnection)
3)Replace the junk black breakers with MRBF fuses on all the 4/0 cabling from positive battery connections
4)Replace the barely sufficient buss bars with overly capable beefy copper bar stock
My question is solely asking what is the most efficient design y'all can think of to paralell these 4 batteries given their size and dimensions. This was the best I could come up with a year ago, but you can see the cable lengths differ slightly, and the batteries are standing on-end. I would like to streamline it more. My brain is still having a hard time thinking of the best "roadway" considering the battery posts are on the long-end of each battery (and closely spaced)
I understand I may have to abandon my entertainment center mounting approach because the batteries just won't fit any other direction (I think)
I don't need to compute amps, cable sizing, wiring instructions or ampacity.
I literally just need to brainstorm a "roadway" for my cabling
Thanks
(See picture)
(bottom-left)
Thanks
