Advice Please -- Newbie Designing Full Solar System w/ Chest Freezer
BillyP
This is my first time working with electric, off grid, solar, everything … here’s where I’m at (and humbly looking for guidance).
Just bought a ’95 Chevy G30 15-psgr van (used as a nursing home transport van), with a hightop and only 60,000 original miles. Converting to a DIY budget campervan, but we’re only planning on using it for vacations: maybe one weekend/month, and two 2-3 week trips each year, so like 50-60 days per year. When we are on these trips, we will probably be driving an average of 2-3 hours/day. We are NOT living in it, so we are only looking to install a minimal to moderate solar system that can power:
2 laptops, 1 iPad, 2 cell phones, 1 hot spot, 1 cellular booster, LED lights, MaxxFan Deluxe … AND
110V Freezer Chest!
I know that there is a lot of debate about the pros/cons of doing a freezer chest conversion vs. 12V DC fridge. When we go camping, we drink a lot of adult beverages . . . we’re on vacation. This seems like to cheapest way to get a big fridge that will keep those drinks cold. And it sounds like the power usage can be comparable or less than a 12V fridge, as long as I don’t have the inverter running 24/7.
The system I have designed is basically built from the starting point of getting this freezer and figuring out how to power it without keeping an inverter on all day.
https://www.homedepot.com/p/Koolatron-Kool-3-5-cu-ft-Chest-Freezer-in-White-KTCF99/301097784
https://www.koolatron.com/CA/en/white-chest-freezer-99l
Importantly, this particular freezer has a thermostat that can go up to 32 degrees, so we’re thinking that drinks and any non-produce food can stay cold, without freezing too much. If that doesn’t work, and it is too cold, we will try and manually alter the thermostat like the home brewers suggest:
https://www.homebrewtalk.com/thread...tat-to-32f-eliminate-external-control.249612/
If either of these methods work, I would not need an external thermostat to regulate the freezer temp: it will either be factory set at 32, or I will manually adjust that upwards, closer to 40.
Because the fridge will be plugged into an inverter all day, I looked for an inverter with a Power Save mode, so that it will only turn on when there is a draw. GoPower inverters have that option:
“Power saving mode enables the inverter to turn itself on and off looking for a specific sized load, yet draw less power than standard operation. When power saving is enabled and the inverter senses a load, it may take one second for the load to become active. This one-second wait will be fine for loads that draw continually, such as televisions and stereos. However, it may not be suitable for loads that are intermittent such as bread makers, power tools or blenders. Power saving will continually draw a small amount of power from the batteries, so if the inverter will not be in use for longer than a day, it is advisable to turn the inverter off using the on/off switch located on the front of the inverter or remote.”
https://gpelectric.com/products/1500-watt-industrial-pure-sine-wave-inverter/
https://gpelectric.com/products/gp-sw1500-ts/
My hope is that when the fridge thermostat goes to turn the compressor on, it will wake the inverter up to provide power. This should only happen a couple of times an hour, and should only run for a few minutes each time.
Another option, would be to follow this poster’s advice, he used a few more components to be able to basically do the same thing—automatically turn the inverter on, only when the thermostat turns on:
So, with the freezer chest conversion as my starting point, I need an inverter that will only turn on when the compressor turns on. After that, I am just trying to install the most cost-effective and efficient components for the rest of my system. I thought we could try to get by with 200W solar and 100Ah lithium. But, I want to make sure that my components can support an expansion to 400W solar and 200Ah, if it turns out that we need more power. Here is where I am at:
Rich 200W Solar: https://richsolar.com/products/200-watt-solar-panel ($200)
SOK 100Ah 12V LiFePO4: https://www.sokbattery.com/products/100ah-12v-lifepo4-deep-cycle-battery?ref=h-cvbzfahsek ($570)
Renogy 50A Solar Controller w/ DC-DC Charger (alternator charging): https://www.renogy.com/dcc50s-12v-50a-dc-dc-on-board-battery-charger-with-mppt/ ($260)
Renogy Bluetooth Controller: https://www.renogy.com/bt-2-bluetooth-module/ ($40)
GoPower PSW 1500W Inverter: https://gpelectric.com/products/1500-watt-industrial-pure-sine-wave-inverter/ ($450)
GoPower 30A Transfer Switch: https://gpelectric.com/products/30-amp-transfer-switch/ ($80)
OR GoPower 1500W Inverter with Built-in 20A Transfer Switch: https://gpelectric.com/products/gp-sw1500-ts/ (this would cost almost $100 more than buying the inverter and TS separately, and give me a 20A TS versus 30A). ($610)
GoPower PSW Inverter Remote: https://gpelectric.com/products/industrial-pure-sine-wave-inverter-remote/ ($90)
GoPower DC Inverter Install Kit: https://www.amazon.com/Power-GP-DC-KIT3-Installation-1100-1800-Watt-2000-3000-Watt/dp/B00153587Q ($190)
All in, before I buy wire, fuses, etc. this brings me to about $1,900 (everything except for the battery is available on Amazon Prime).
Again, I have no experience. Can y’all who have done this before, and know what you’re doing, please offer me advice on any issues you see with my design/goals? Thanks in advance!!
I don't see anything wrong with the basic theory (e.g., temperature sensor to flip a relay on an inverter). But wouldn't it be easier to get a DC freezer? Not an inefficient Peltier freezer, but one with a DC compressor (the most efficient refrigerators today convert the AC to DC to run the compressor).
I don't see anything wrong with the basic theory (e.g., temperature sensor to flip a relay on an inverter). But wouldn't it be easier to get a DC freezer? Not an inefficient peltier freezer, but a real one (the most efficient refrigerators today convert the AC to DC to run the compressor).
Easier and possibly more efficient. But the main reason people opt for the chest freezer + thermostat controlled inverter route is cost. DC fridges (in larger sizes can be pricey, and chest freezers are cheap. (not sure if this is OP's reasoning or not).
OP one thing I would point out (in relation to your inverter + power save mode), I have heard multiple times that modern fridges often don't play well with power save mode. I can't remember specifically why.
compressor fridges don’t always provide enough load for power save modes to sense and wake up for. firsthand experience.
perhaps others have had different experiences, would like to learn as much as possible about fridges and power save modes on all combination of hardware.
The main advantage (other than price) for what he wants to do is . . . the cheap chest type freezer has better insulation than most DC fridges and when you use that big freezer as a fridge set to 40 degrees, it uses way less power than when it was set up to run at 0 degrees as a freezer
They do make kits specifically for this conversion, which give you an adjustable thermostat designed to work in the 35 to 45 degree range. I would invest in one of those kits and not try to make it work using the thermostat installed in the freezer
Don
I run a chest fridge with literally no battery storage. Easy to isolate thermostat switch for inverter use. Demand inverters aren't that good. When battery voltage is high enough and thermostat demands, fridge turns on for a timed period. It can continue or shut off till battery recovers. In this way your fridge stores cold. This works for me all summer, a fridge that operates only in the day when sun is shining and no more that 6 minutes of battery is ever used. Its complicated so maybe you better do what everyone else tells you.
