jolondon
Hi.
I am installing a 6kw System here in Costa Rica at an off grid location consisting of an EG4 6ooo XP inverter and four EG4-LLS 100 AH batteries. I am installing on my property on the Caribbean side of Costa Rica, which is hot and humid.
I have two questions:
1) The temperature in the bodega, which is 4x3.75x 2 meters, is approximately daytime 80-85 degrees with a humidity around 85% also. As you can see in this picture I had left space at the top for ventilation but now I realize that I should have sealed it. I understand that humidity not temperature is the real enemy of solar equipment (the equipment is rated up to 100 degrees or so). My question is I can seal the top of the bodega as is or would it be wiser to cut the bodega in half with an interior wall so I am dehumidifying a smaller amount of space. I understand that it will be less work for the humidifier to dehumidify a smaller space but I also wonder if a smaller space wouldn't heat up faster? I can't place an ac in there because of the energy draw (this is an off grid location). fyi I purchased a 2500 foot dehumidiifer.
2) I am looking to alternatives to ac such as using fans. It doesn't seem an exhaust fan would do any good as I would be briniging in humid air from the outside which is what I want to avoid. From online research I did it seems the best way to cool components with a fan is to use the fan to pull the hot air away from the component. What are thoughts about using a front exhaust fan like this that would pull the hot air away from the batteries/inverter? I It only draws 8 watts. With my flexible shelving I can easily fit one on top of each battery (either directly on top or on a shelf). A few guys who have this type of fan said that it keeps their computer servers cool. thoughts or is there a better way to cool equipment without ac?
Thanks in advance for any and all help.
