Hey friends, I am trying to help my parents get their well pump setup on solar. They had been running it on a generator that just blew up so the house backup is currently being used down at the pump house. I am trying to see if we can move towards solar instead of buying another generator. They are fully off grid and have a separate 48v system for the house but it is 150yards away. The pump only needs to run occasionally so we can maximize peak sun hours and only turn on the system when it is sunny (they live in the High Desert of Southern CA so that's pretty much every day). They pump to holding tanks then gravity feed into the house/property.
The pump is a 1.5 HP Franklin.
What we currently have to use for the system:
30 used 175w 44voc panels
6 8v 245amp hr used deep cycle batteries that used to run the 48v house system before I upgraded them to Lithium.
My questions:
Would the 5kw Growatt (spec below) work for this system?
Could I avoid wiring up the batteries and just run the system on solar?
What am I overlooking? I certainly don't want to blowup the well pump with an undersized system but budget is a factor.
My questions:
