SParker42
- Oct 5, 2022
- 4
I am imagining a temperature maintenance solution for a LiFePO4 battery bank in a van to protect them from low temperature charging.
The scenario I am trying to protect the big (for a van, only about 10KWH)24V LiFePO4 battery bank from is one where a van is left parked outside for a few days and the weather gets cold. Maybe even a bit of snow for a day or two that temporarily interrupts charge from the solar array. The LiFePO4 batteries are disconnected from the charge controller as a precaution (I know the picture shows them connected, but I wanted to emphasize that the two solar charge controllers are working in parallel from the same array). In "normal" operation the van is warm, the LiFePO4 batteries are connected as shown and the heating pad is not doing anything because its temperature control circuit has it turned off.
There's a rectifier to isolate the load output and charge outputs from the AGM's charge controller. There's also an under voltage discharge protection circuit on the AGM. However, the solar array is very oversized for the AGM and the sub-freezing response operation would keep the LiFePO4 warm with help from the load output of the charge controller during the day, and then the AGM would keep the LiFePO4 warm all night by itself. The AGM would charge during the day
I've been told that charge controllers can be run in parallel without misbehaving, but never specifically if a 12v AGM charge controller can run in parallel with a 24V LiFePO4 charge controller. I figured it would be good to isolate the load and charge outputs from the AGM charge controller, and I can get my hands on great big rectifiers, and thought they could do the trick.
I've spent a couple hoirs going over old posts to see if my questions could be answered and did not see anything. That doesn't mean it's not there, just that I did not find it in this forum. My feelings will not be hurt if there is something glaringly obvious and you point it out to me. That's kinda why I am asking this question.
