Hi all!
I have had the AiLi battery monitor installed on my RV now for going on 3 years and it's been amazing. Up to this point I have used it only with shore power, when we dry camp and use a generator everything works perfectly, the Volts, Amps, Ah and % has been dead on (based on my volt meter testing). I have two Trojan 6v T-105s wired in Series which has performed fantastic. Now I have entered into the Solar arena, and I have a 100w DOKIO 18v portable hard sided solution I wanted to try out, hoping to reduce generator usage when dry camping, and specifically when we leave our site. When I connect the alligator clips to my +positive/-negative going TO/FROM the RV I do see my 'volts increasing' on my AiLi inside the RV however my symbol still shows the down - arrow, which means it has a negative draw. Additionally, on the AiLi my % is still decreasing as well as my Ah which when I charge from shore power I always see a + up arrow indicating I've got a charge going back into the batteries, my percentage always increases along with my volts and Ah etc. Last data point, on my solar PWM charge controller it shows roughly 1.4-2 Amps going back into the RV. I do realize at this point in time that is not a lot, but on the RV my parasitic draw is only .126 which is much less Amp than should be going back into the RV.
Anyone else use a portable Solar kit and connect directly to your batteries like this? Any thoughts on how to fix this, or other suggestions from you experienced folk?
