I have this monitor and it seems to work ok. But I got the 100 (or maybe even 50) amp version and need to increase the shunt capacity. There are numerous shunts available and I'm thinking it may be possible to just swap shunts. But there appears to be two "standard" designs: 50mv or 75mv. I'm not clear what this spec actually means. Anybody?
If it means shunt readout at max nominal amps, my idea may be problematic unless I can find a way to set amps/shunt voltage in the meter. Might not be worth the trouble.
Thanks for any insight here.
Rufus
Rufus
