BlakeQuake
- Jan 4, 2022
- 7
Hello. The problem is with the AiLi Battery Capacity Monitor. It seems to only be reading half of the amp inputs, and outputs, as well as capacity.
For example: There is a 10 amp draw/load on a 100ah battery. The monitor reads it as 10amps. (perfectly fine), but as a 2x100ah battery bank (200ah) the monitor reads it as a 5 amp draw/load. I know why this happens, because the load is evenly pulled across both batteries. My question is why am I not getting the full draw/load reading across both batteries? This also applies to the capacity. When switching my battery bank setting to 200ah the battery dies at %50. So why am I stuck with just the 100ah setting even though I have 200ah? I am able to run 2000w loads from my battery bank so I know both Battleborn batteries are working.
