Hi all,
just installed AiLi battery monitor prior to sunrise this morning all wiring correct, monitor showed charge and discharge and worked perfectly. As it was early morning prior to sun rise I drove the vehicle and the monitor showed approximately 10 A charge from the alternator as the batteries were reasonably full.
My problem is, I woke up this morning to see if the monitor was showing charge from the solar panels but nothing! It just continues to show discharge. I have disconnected the small B+ wire from the battery terminal and reconnected with no joy, other than the monitor not showing charge now it’s still working perfectly.
Has anyone had this issue any help would be appreciated.
Is there a factory reset for the monitor as the manual does not state one.
Thank you
Thank you
