MadMacks
Off Gridder
I have an off-grid set up using a few solar panels (630 watts), a custom built LiFePO4 battery with JBD BMS, a Renogy MPPT charge controller, and a AIMS PICOGLF25W12V120AL inverter/charger. The AIMS is powering a chest freezer and a few other small A/C based items. The problem I’m trying to address is that the BMS will disconnect the battery when it hits an over voltage thresholds (like it should) or a battery full condition. When that happens it triggers a fault on the inverter, and it cuts off and starts putting out an audible alert beep. This happens, usually, around early afternoon when the battery is fully charged. If I’m around and hear the audible alert I go hit the on-off switch and things go back to normal, even if the battery is still disconnected due to the BMS protecting it. The AIMS gets enough power from the solar panels to power things just fine. And when the battery voltage drops the BMS turns the battery back on and things go back to normal.
I will probably fiddle with the settings on the Renogy MPPT controller and BMS to not quite take the battery to a high voltage cutoff level, so that might resolve the issue, but I’m wondering if there is some other way to resolve the problem differently. I’m not sure if the AIMS sees the momentary voltage change when the BMS shuts off the battery as an “error” and throws a fault, or exactly why the AIMS is shutting down (as there’s no log to show the fault condition that causes the shut down), but I really don’t want to lose a chest freezers worth of food if I’m not around to hit the on/off switch and get the AIMS running again.
Any ideas?
Any ideas?
