Chucklesbtoken
- Sep 19, 2021
- 5
I have the MPP Solar PIP-1012LV-MS. 200aH LiFePO4 and 12v hub
Is it okay to put all positives to bus bar and all grounds to a bus bar (with ground also going to chassis)??
I have all the breakers and wire gauges worked out but not sure with AIO units if this would be the approriate grounding or if I should be connecting the SCC to the battery and then battery worked off of that. I guess its the same thing in essence? Im still very new but I did buy 2 blue sea bus bars thinking to use them but then I hear maybe chassis ground is not suitable for all setups
Also, Having a hell of a time finding the approriate breaker for solar panels I have 2x 200w in series so V (optimal conditions) is right around 50V. Help with breaker for inbetween solar panels and SCC would be much appreciated. I figure to have a breaker for maintenance/dc-dc charger..
dc-dc charger being another reason for in the future wanted to have bus bars ready for easier addition
