just installed a 100a powermr charge controller, all working good... but...
Noted that when the fans kick in the air is sucked from the two TOP fans and pushed down and out of the lower side vents
I thought that normal convention would be to suck "cool" air in from the lowest point of equipment around the bottom/sides and blow out the top.
mine seams to be blowing air the wrong way going against heat convection principles of hot air rises
any thoughts?
see attached photo.
Cheers,
Richard
any thoughts?
see attached photo.
Cheers,
Richard
