AiLi Battery Monitor Voltmeter Ammeter Voltage Current Meter 8-80V 0-100A
I am going to purchase one of these units. My system is a12 VDC 220 amp-hour lead-acid battery source. And my inverter is rated at 1200 watts continuous, with a 100 amp breaker as protection. This is charged by a 400-watt solar panel set up on a 30 amp charge controller. I assume I can get by with the 100 amp shunt unit instead of the 350 amp ( on backorder), because my breaker is 100 amps .
However, my question is set up. I want to limit my battery depth of discharge to 50 % and have the meter display what power out remaining would be using that limit. So hypothetically do i use 110 amp-hours as a set point?
