All EV's PowerWalls, Grid Storage Blocks, regardless of Lithium Chemistry only used fully & properly Matched Batched & Binned cells. This is critical is such applications because even one bad cell can cause havoc and through things out of whack. All Lithium Cells are super sensitive to the voltages and temps, not like most other battery types. I gave you a tiny brief snapshot about balancing, I can give you white papers & technical references etc if you want to digest it all, it is dry and quite boring reading.
PreBuilts by generic vendors/makers are a 50/50 proposition. IF you want to go that way, look at CHINS (Will just did another review & teardown)
or AmpereTime, or step up to Gyll by Signature Solar.
https://shop.signaturesolar.us/pages/eg4
Want guaranteed good pre-builts, then you get to BattleBorn and that set which now is getting into serious change.
If you are 12V then buy 12V Batteries or build 12V. If you are going 24V or 48V buy prebuilts for THAT voltage or build for THAT voltage... Do not cobble together batteries in series to build up for Voltage. BATTERIES are the FOUNDATION of the system and must support it, just like a building foundation has to support the structure on it.
Laser Welded Studs outperform standard studs.
Few vendors offer it but they are available.
Compare identical cells of the same grade/class otherwise you'll only suffer confusion. You have 280's 272's, 200, 100's and different grades shown.
MAKE A PLAN & STCK TO IT... Failure to Plan, is a Plan to Fail ! and that is always co$tly.
State what exactly your target is, 12,24,48V
How many watts / amps your going to draw constantly & surges handling
Know how big the battery system needs to be to supply enough energy for the time required for use.
Understand that the Battery Size needs to have enough Solar / Charger capacity to charge within the time available. A 30A Solar Charge Controller could never fully charge a 48V/280AH in <5 hours of daylight, not even close. And neither would a small 400W solar array.
To work out the kWh the formular is: (#of-cells * 3.2V nominal) * Cell-AH-Rating. [12V/100AH example] (4*3.2) 12.8*100AH = 1,280wh or 1.2kWh
