CamperDude
- Oct 30, 2020
- 19
Anyone have experience using ali express charge controllers?
I'm kind of discouraged by the outrageous price of MPPT chargers for my small 300w solar setup in my van. Then i found this on aliexpress
Thoughts?
● Advanced MPPT maximum power point tracking technology, the tracking efficiency is no less than 99.5%.
● High quality components are used to improve the system performance, and the maximum conversion efficiency can reach97%.
● Super fast maximum power tracking speed while ensuring tracking efficiency.
● Accurate identification and tracking of the maximum power point of multi-wave peak.
● Reliable maximum input power of pv array to ensure the safety of equipment.
● Wide pv array maximum power point operating voltage range.
12/24v automatic voltage identification
● The LCD is designed to dynamically display the operation data and working status of the equipment.
● Various load control modes: general mode, light control mode, dual time mode, pure charger mode and timing mode.
● Seal, GEL, Flooded, LifePO4 and Li(NiCoMn)O2 charging process can be selected.
● The function of battery temperature compensation.
● Power statistics recording function.
● Use the RS485methods to maximize the communication needs of different occasions.
● Support PC monitor, external display unit and other peripherals, realize real-time data view and parameter setting function.
Thoughts?
