I didn't notice any issues with your initial diagram, but I agree that you will probably end up wanting more than 400w of solar and might as well plan for it now.
In my opinion the main way to plan for more solar is to pick a solar controller (whether standalone or built into an all-in-one inverter) with the highest max voltage rating, because it will simplify the additional wiring when panels are added. For example, if you did get a controller with 400v+ input limit, it would be difficult to integrate enough panels onto the top of a travel trailer to necessitate any parallel wiring. If you can keep all the panels in series it will simplify both the initial install of wiring, and the changes necessary to add panels down the road (assuming the new panels somewhat match the existing ones). I think the main thing you would want to avoid is the need to create new roof penetrations or upsize the existing cabling going through your penetrations, because that is irritating and just one more possibility for leakage.
And if you are planning for full-time living, you have to consider air conditioning and heating. Air conditioning on solar is 'feasible' in mild conditions on a solar powered RV/TT setup, but not really in hot conditions, and electric heating is likewise not particularly feasible. So for example your 2200w inverter would comfortably run 2 small 5-6000btu/hr units as long as they didn't start up simultaneously. It would probably run one larger ~8k unit. It probably would not be able to start a typical 12-14k rooftop unit. So you either decide that AC use will be limited to generator power, or you plan both the supply side (solar/inverter/batts) and the load side (the ac units) to play nice together from the get go.
I have a somewhat similar situation to you in that i have ~360ah (rated..) of 12v lifepo4 in my RV. I have a ~12-14k rooftop unit which i hate because it's a power hog, and stuck a typical 5kbtu window unit through a back wall. I CAN run that rooftop unit off my 5kw inverter if i chose to, but i choose not to because the continuous 150a+ draw on the 12v side makes me paranoid, even though the system can handle it for a certain amount of time. It just makes me uncomfortable knowing it's happening. I do plan to work on upgrading my wiring until it is feasible to run it continuously when driving off my 200a rated alternator, but im not there yet with my wire sizing/connections. You couldn't run a unit that large off a 2200w inverter at all. However, I can run my 5k window unit quite comfortably for many hours. Overnight off the batteries if needed. During the day i would need to have around 500w of solar to 'break even' and power the unit without drawing down the batteries. The cool thing about AC off solar/inverter/batteries is you don't HAVE to 100% break even from solar. But if that unit would run 8hours or something with no solar, it would run ~16 if i had 200w of solar coming in, etc. Forget that 16 hours of sunlight isn't a thing, just making an example. So if you ever plan to run AC off this setup you should decide that NOW, to minimize the amount of incremental changes you have to make down the road. If you choose not to then it's possible that a 2200w inverter would be all you ever need for most uses, but you will still probably want to end up with more than 400w of solar coming in.
