3.2KW off grid inverter without battery working with MPPT 24V80A
Description:
This is a multi functional inverter/charger, combining functions of inverter,solar charger and battery charger to offer uninterruptible power support in portable size. Its comprehensive LCD display offers
user-configurable and easy-accessible button operation such as battery charging current,
AC/solar charger priority, and acceptable input voltage based on different applications.
Features:
1.High effciency pure sine wave inverter(PF=1);Wide PV input range (120V dc -50V dc) 80A MPPT SCC;Intelligent 3stage 80A AC battery charger.
2. Surges to 2X continuous power for 5 seconds for motor loads.
3. Intelligent functionality enables utility and solar input prioritization.
4. Wide ulility input range (90Vac _280Vac) for unreliable grid even in the most challenging environments.
5. Field serviceable with replacement boards and spare parts.
6. Monitor, troubleshoot, or communication with USB/RS 232.
7. System configures quickly into compact, wall-mounted system.
Specifications:
Model | MPS-V 3200-24 |
RATED POWER | 3200VA / 3200W |
INPUT | |
Voltage | 230 VAC |
Selectable Voltage Range | 170-280 VAC (For Personal Computers) ;
90-280 VAC (For Home Appliances) |
Frequency Range | 50 Hz/60 Hz (Auto sensing) |
OUTPUT | |
AC Voltage Regulation (Batt. Mode) | 230 VAC ± 5% |
Surge Power | 6000VA |
Efficiency (Peak) | 90%~93% |
Transfer Time | 10 ms (For Personal Computers) ; 20 ms (For Home Appliances) |
Waveform | Pure sine wave |
BATTERY | |
Battery Voltage | 24 VDC |
Floating Charge Voltage | 27 VDC |
Overcharge Protection | 32 VDC |
SOLAR CHARGER & AC CHARGER | |
Max. PV Array Open Circuit Voltage | 500VDC |
Max. PV Array Power | 4000 W |
MPP Range @operating Voltage | 120~450VDC |
Max. Solar Charge Current | 80 A |
Max. AC Charge Current | 60 A |
Max. Charge Current | 80 A |
PHYSICAL | |
Dimension, D x W x H (mm) | 100 x 300x 440 |
Net Weight (kgs) | 9 |
Communication Interface | USB/RS232 |
ENVIRONMENT | |
Humidity | 5% to 95% Relative Humidity (Non-condensing) |
Operating Temperature | -10°C to 50°C |
Storage Temperature | -15°C to 60°C |
System Diagram :
Operation with battery connected :
Operation without battery connected
Inverter Detail
Packing
Factory View
Certificate :
