NewGuyNoob
- Jul 30, 2021
- 86
Here are the ModBus Maps for these Conext Devices, XW/XW+ , Microsoft Onelink shared below and attached to this thread:
SE Devices OneDrive Link PDF’s - Below:
503-0244-01-01_RevA.4_Modbus_Map_Conext_SW_Device.pdf
503-0245-01-01_RevA.4_Modbus_Map_Freedom_SW_Device.pdf
503-0246-01-01_RevA.4_Modbus_Map_Conext_XW_Device.pdf
503-0247-01-01_RevA.4_Modbus_Map_AGS_Device.pdf
503-0248-01-01_RevA.4_Modbus_Map_MPPT60_Device.pdf
503-0250-01-01_RevA.4_Modbus_Map_GridTie_Device.pdf
503-0251-01-01_RevA.4_Modbus_Map_SCP_Device.pdf
503-0252-01-01_RevA.4_Modbus_Map_MPPT80_Device.pdf
503-0253-01-01_RevA.4_Modbus_Map_ConverterComBox_Device.pdf
503-0261-01-01_RevA.4_Battery_Monitor_Device.pdf
503-0262-01-01_RevA.4_Freedom Sequence Device.pdf
configuration.yaml
OK, So is anyone integrating the 6.8K into their setup using closed loop communication with their EG4 batteries? I am trying to get SOC to show up in my HA setup. I can get anything else, except that. My insight Local, says my slave address for the BMS is 230, but that address is dead.
Anyone have any success?
configuration.yaml
YAML:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
# Text to speech
tts:
- platform: google_translate
automation: !include automations.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
sensor: !include sensors.yaml
influxdb:
host: a0d7b954-influxdb
port: 8086
database: homeassistant
username: homeassistant
password: homeassistant
max_retries: 3
default_measurement: state
modbus:
- name: conext_gateway
type: tcp
host: 192.168.86.245
port: 503
delay: 2
timeout: 15
#Always double check your address for each device.
#conext_gateway Device over MODBUS: XW Pro 6848 Bus ID 1, Bus address 0, Modbus SlaveAddress 10 (Port 502/503)
sensors:
# - name: "Load AC Power"
# data_type: uint32
# unit_of_measurement: W
# scale: 1
# slave: 90
# address: 132
# device_class: energy
# - name: "AC Input Power"
# data_type: uint32
# scale: 1
# slave: 90
# address: 100
# - name: "Charge DC Power"
# data_type: uint32
# scale: 1
# slave: 90
# address: 92
# - name: "Load Output Energy Today"
# data_type: uint32
# unit_of_measurement: kWh
# scale: 0.001
# precision: 1
# slave: 90
# address: 220
# state_class: total_increasing
# - name: "Energy From Battery This Hour"
# data_type: uint32
# scale: 0.001
# precision: 1
# slave: 90
# address: 144
# - name: "Energy to Battery This Hour"
# data_type: uint32
# scale: 0.001
# precision: 1
# slave: 90
# address: 168
# - name: "Generator Status"
# data_type: uint16
# scale: 1
# slave: 51
# address: 77
# - name: "Generator to Battery This Hour"
# data_type: uint32
# scale: 0.001
# precision: 1
# slave: 90
# address: 192
# - name: "EG4 Internal BMS - Battery SOC"
# data_type: uint32
# unit_of_measurement: V
# scale: 1
# slave: 230
# address: 70
- name: "XW 4868 Inverter Enabled"
data_type: uint16
input_type: input
slave: 10
address: 71
- name: "XW 4868 Active Faults Flag"
data_type: uint16
input_type: input
slave: 10
address: 75
- name: "XW 4868 Active Warnings Flag"
data_type: uint16
input_type: input
slave: 10
address: 76
- name: "XW 4868 Battery Current"
data_type: int32
input_type: input
count: 2
slave: 10
address: 82
unit_of_measurement: A
scale: 0.001
offset: 0
precision: 3
- name: "XW 4868 Battery Power"
data_type: int32
input_type: input
count: 2
slave: 10
address: 84
scale: 1
offset: 0
precision: 0
- name: "XW 4868 Battery Temperature"
data_type: uint16
input_type: input
slave: 10
address: 86
unit_of_measurement: degC
scale: 0.01
offset: -273
precision: 2
- name: "XW 4868 Inverter Status"
data_type: uint16
input_type: input
slave: 10
address: 122
- name: "XW 4868 Load AC Voltage"
data_type: uint32
input_type: input
count: 2
slave: 10
address: 140
scale: 0.001
offset: 0
precision: 3
- name: "XW 4868 Load AC Current"
data_type: int32
input_type: input
count: 2
slave: 10
address: 150
scale: 0.001
offset: 0
precision: 3
- name: "XW 4868 Load AC Frequency"
data_type: uint16
input_type: input
slave: 10
address: 152
unit_of_measurement: Hz
scale: 0.01
offset: 0
precision: 2
- name: "XW 4868 Load AC Power"
data_type: int32
input_type: input
count: 2
slave: 10
address: 154
scale: 1
offset: 0
precision: 0
scan_interval: 1
#conext_gateway device over Modbus: MPPT600/100 0 - Bus ID:1, Bus address:1, Modbus Slave Address (Port 503): 170
- name: "0 - MPPT100/600 100/600 Device State"
data_type: uint16
input_type: input
slave: 170
address: 64
- name: "0 - MPPT100/600 Charger Enabled Status"
data_type: uint16
input_type: input
slave: 170
address: 65
- name: "0 - MPPT100/600 Charge Mode Status"
data_type: uint16
input_type: input
slave: 170
address: 67
- name: "0 - MPPT100/600 100/600 Active Faults"
data_type: uint16
input_type: input
slave: 170
address: 68
- name: "0 - MPPT100/600 Active Warnings"
data_type: uint16
input_type: input
slave: 170
address: 69
- name: "0 - MPPT100/600 PV Input Voltage"
data_type: uint32
input_type: input
count: 2
slave: 170
address: 76
scale: 0.001
offset: 0
precision: 3
- name: "0 - MPPT100/600 PV Input Current"
data_type: uint32
input_type: input
count: 2
slave: 170
address: 78
scale: 0.001
offset: 0
precision: 3
- name: "0 - MPPT100/600 PV Input Power"
data_type: uint32
input_type: input
count: 2
slave: 170
address: 80
scale: 1.0
offset: 0
precision: 0
- name: "0 - MPPT100/600 Battery Temperature"
data_type: uint16
input_type: input
slave: 170
address: 86
scale: 0.01
offset: -273
precision: 2
- name: "0 - MPPT100/600 PV Output Voltage"
data_type: int32
input_type: input
count: 2
slave: 170
address: 88
scale: 0.001
offset: 0
precision: 3
- name: "0 - MPPT100/600 PV Output Current"
data_type: int32
input_type: input
count: 2
slave: 170
address: 90
scale: 0.001
offset: 0
precision: 3
- name: "0 - MPPT100/600 PV Output Power"
data_type: uint32
input_type: input
count: 2
slave: 170
address: 92
scale: 1
offset: 0
precision: 0
- name: "0 - MPPT100/600 Energy From PV This Hour"
data_type: uint32
input_type: input
count: 2
slave: 170
address: 112
scale: 0.001
offset: 0
precision: 3
- name: "0 - MPPT100/600 PV Input Active This Hour"
data_type: uint32
input_type: input
count: 2
slave: 170
address: 114
unit_of_measurement: s
scale: 0.001
offset: 0
precision: 3
503-0253-01-01_RevA.4_Modbus_Map_ConverterComBox_Device.pdf133.7 KB · Views: 5
