Cabinfever
- Jun 22, 2020
- 25
Hi all and thanks for your help so far. It wont be long now and I will be ready to hook up my off grid system.
*MPP LV 2424 Hybrid All in One Unit
*Qcell 425 W Panel
*4 six volt 220 amp hour golf cart FLA batteries
I want the ability to completely shut down the system when I leave the cabin. So, first off from what I read in the MPP LV 2424 manual, a 125 Amp breaker/fuse will be what is needed from batteries to LV 2424, is the info correct? Should I go with an ANL fuse and cut off switch or just a DC breaker which will serve both purposes.
For the PV wires, can I also use a DC breaker for protection and shut off of the system? Based on the photo I have included which show the panel specs as well as the LV 2424 specs , what are your thoughts. Batteries will be within 5 feet of LV 2424 and panel will be around 25 feet from LV 2424 using 2 AWG wire from batteries to LV 2424. What size breaker is required for panel please. Once I get these items I can go ahead and set it up. Your help is always appriciated.
Also the LV 2424 manual says to use 6 AWG wire to panel, is this right, my panel has 12 AWG and most people I see are using 10 AWG....thoughts ?
MPP LV 2424 includes:
*Qcell 425 W Panel
2400W 24V
80A 24V Solar Charge Controller
60A Ac Charger
Supports up to 2000W of Solar
