Alternative way to upgrade firmware on JK BMS
mortenmoulder
Denmark
I've got an JK PB2A16S20P BMS as well as an "RS485 to TTL" board, that has RX, TX, VCC, and GND as input. I've also got a bunch of ESP32, ESP8266, Raspberry Pi, and so on laying around.
I tried forwarding the serial communication on baud rate 9600 and 115200 with an ESP32, but I was not able to get the JK BMS software on Windows to pick it up. I can see it sends a command every second or so, as the RXD LED on the RS485 to TTL board blinks.
Is there an alternative way? I see plenty of people integrating their BMS into Home Assistant and so on, so I figured someone must have found a way to eliminate the Windows application.
