Sipma02
- May 27, 2020
- 141
Hello all! I've been snooping around here for the past few weeks, and have all my questions answered by searching and just reading and researching. There is such a wealth of knowledge, it's incredible!
I'm currently working on building out a 2006 Sprinter (you can see details here: https://www.facebook.com/groups/573929156547519) and I've come across LiFePo4 batteries and being pretty much ideal for a house/leisure battery setup.
I've done a fair amount of research, and there are a staggering amount of options. I know I want a pretty big battery bank, and I plan on getting 4 280ah 3.2v Xuba Lifepo4 batteries and wiring them in series for a 12.8v pack. There's a strong possibility that I would add another 4 3.2v 150ah or possibly even another 4 3.2v 280ah down the road. Our daily predicted energy usage is around 1Kw, and we want to be able to be offgrid for 3-5 days. I'll for sure be running a BMS, probably a Choice BMS or Electrodacus.
My roof setup pretty much dictates that I stick with 450 watts of solar, split between 3 150 watt panels. By my calculations, this isn't really going to be enough solar. It will help extend our time between drives though. We want as much flexibility as possible. Since we'll be full time in the van, we'll probably be driving pretty frequently. The van has a 150 amp alternator, and after standard vehicle loads, I can draw about 80-100 amps from the alternator. Estimating conservatively, 60-80 amps. I'd like a DC DC charger capable of charging the 280ah (and potentially larger in the future!) pack as fast as possible/least drive time possible.
The Xuba cells are rated for at least a .5C charge rate, and .5C with a 280ah pack is 140 amps! So the fastest I can really charge is around .3C or so (~80amps from the alternator)
The main problem I'm running into is all the DC DC chargers rated for 50+ amps are very expensive. I currently have my eye on the Kisae DMT1250, which will provide 50amps of alternator and solar input. If I go with the Electrodacus, it has a built-in solar controller, but isn't the most efficient (PWM vs MPPT) but I've read that might not be as big of an issue as I think. I would still need a large/expensive DC DC charger...
• Can I wire 2 DC DC chargers in parallel?
• Something alternative to a DC DC charger? (just confirming... I do need a DC DC charger, correct? The BMS does not take place of a DC DC charger, right?)
• Is there any BMS options with a build in charger?
• Could I parallel a set of these instead of a DC DC charger? https://usa.banggood.com/1200W1800W...c-Vehicle-Booster-p-1599490.html?rmmds=search
• Are there any other options I have?
...Hoping for some wisdom here! As you can see, I know enough to be dangerous... or maybe not. Ha. Thanks so much
