I plan to get two 24v 200Ah LifePO4 batteries. Should I run split phase with 1 bank I have two 4400 watt inverters. Can't I get by for starters with two batteries in 1 parallel bank? That would be 9600 Wh available to each inverter so if only one inverter has loads it would have access to all the power. Otherwise they would just share the benefits of going Lithium.
You would need the house batts to be wired in parallel to keep 24v, if that is what the starter batts provide.
Wire your inverters to the house batts.
You would then wire the positive posts of the starting batts to the positive posts of your house batts, with an isolator switch along the run, so you can isolate the two banks.
This will allow you to run all of your house loads through your inverters, like your A/C units, and keep the house batts charging from the alternator.
But you would need to isolate the starter batts, or else you may not be able to start the engine when parked.(!)
When you are parked, you would drain the house batts, and once the DD60 is running, you could then tie the two banks together to charge the house batts.
Lithium batts don't take kindly to the high currents required to turn a starter motor, so they shouldn't be tied together until the engine is running.
As well, Alternators don't take well to the high currents that Lithium batteries can draw for long periods without some sort of buffer, like a lead acid bank, so your set-up is effective for both those issues. (as long as the starting batts are 24v)
