Bzzzt
- Jun 17, 2020
- 34
I thought I'd throw this out there since if it happened to us it will probably happen to someone else.
We noticed a low charge rate of 20 amps to the 240Ah LiFePO4 house batteries in our Ram Promaster (100A is more typical). This coincided with a check engine light. A multimeter showed around 13.6 Volts at the alternator rather than the usual 14.7. I figured we had finally blown up the alternator with our high current draws.
However, a code reader showed that the air intake temperature sensor had failed. This turned out to be a bad connection rather than a bad sensor (it's just a ntc thermistor, pretty hard to break).
It appears that when the sensor fails the van looks around for any other temperature information it has and/or picks a safe guess. Apparently it decided that the temperature was very high and lowered the alternator voltage in order to keep a safe voltage on the van AGM battery.
A sliver of a guitar picked fixed the connector and the new alternator gets shipped back to Rockauto.
Hopefully this can save someone out there some hassle!
