StephenV
We just purchased an off grid straw bale home in the San Luis Valley in CO. The current system I inherited was installed in 2019:
8 x 305 W Longi (mono crystalline ) panels into a 4.4KW Magnun Inverter. (Batteries are flooded 48V but unfortunately not really able to hold a charge anymore.
Loads:
Well water pump (1500W) runs once ever 2-3 days for 10mins
Induction cook top (used during day only)
8-10 Incandescent lights have 4-5 on at most
Standard home refrigerator/freezer
Small electronics, laptops, internet gateway etc
(Propane on demand water heater, and hob oven for cooking/baking when not using induction cook top.)
Find the home to be incredibly efficient to keep temperature controlled. (wood burning stove for when it gets cold. Even with temps at 20F at night it still stays comfortably above 60F inside.
The rub:
Our lender is requiring a redundant heat source in the home. Before we got here I had already planned to upgrade the solar because of the aging batteries. While I was upgrading the solar I figured might as well throw a 12k BTU EG4 heat pump in the mix to appease the lender (really trying to avoid more LPG components)
Specs for upgraded system:
9x Aptos bifacial panels 440W (will keep Longi panel array)
6x Lifepro EG4 100Ah 5.2Kw 48V server rack batteries
1x Flexboss21 12Kw AIO inverter (12Kw is overkill but specs for the right inverter were extremely hard to find. Needs to be outdoor rated, operate at -15F and at 8000ft (EG4 will derate the inverter for altitude)
All of this to accommodate the heat pump for the lender that we will most likely never use. (home has been here 22+ years never needed extra heat other than wood stove)
Total estimated cost of system ~17k with 30% tax rebate comes in around $12.5k. It’s expandable and we’ll never want for electricity.
Alternatively I can just purchase 4 server rack batteries more than double the capacity of the old battery bank at its peak 8Kw usable DOD and then install a Rinai gas unit as the secondary heat source. ($1500 for heater and ~$1500 for install)
All in around $6500 (after rebate on LiFeP04 batteries)
Half the cost no extra array that needs to be installed by me. Effectively no compromise in electric usage on our part. We’ll still have the redundant heat source to appease the lender.
Am I being short sighted as to electric demand in the future. Better to pony up the extra $6k now and have more options. We don’t live extravagantly. No other big electric devices, life is more simple here and we like it that way.
Any insight or advice would be greatly appreciated.
