If hydronic has been used in commercial for decades why haven't it transitioned into residential?Any decent heat pump would compensate for this as it's monitoring internal telemetry. Newer ones run the fan (and compressor) using PWM so would speed up at higher altitudes to normalize the system. All DC.
- Mini-splits mean running refrigerant into the house which has lots of extra connections. (leak potential) 350psi vs 20psi for hydronic?
- Mini-splits make you install a gargantuan internal evap unit on the wall, unless in the rare case you have room to install an above-ceiling unit.
- Mini-splits in most cases are one outdoor unit and one indoor unit for each zone. This is ridiculous. Of course there are VRF units but few do their research, and VRF units have the same other drawbacks. The Frankenstein of mini-splits...
- Mini-splits can not heat DHW. Air-to-water can, with the same outdoor unit and a dedicated indoor buffer tank.
- Mini-splits can not be adapted to evac-tube solar.
- Mini-splits can't use the most advanced refrigerant (R-290) for safety reasons.
- Hydronic has been used in commercial buildings for 60 years, for a reason: it's the most efficient. Take a lesson.
- Monoblock air-to-water have all refrigerant in the outdoor unit, factory-sealed and tested.
- Monoblock air-to-water have a CoP approaching 5.
Mini-splits are a preposterous solution to me, and I'm a developer.
Shit, I'm OT. (White knuckles for getting relegated to Chit-Chat again...)
When you say thermal storage I'm taking it as you don't mean buffer tank, or maybe you do?
I found an nice fella out in West Virginia last winter that sold me his Ecko gasification unit. He was 83 and his wife told him he was done burning wood. He practically gave it to me, plus any extra parts and other things he had he gave me. I already had 1400 gallons of tanks for thermal storage.Outdoor wood boiler maybe? Something like: https://heatmasterss.com/
Most use 500 gallon LP tanks. Using a gasification boiler requires a hard and fast burn using a batch burn The heat generated needs to be removed quickly and thus the reason for the thermal storage tanks. When heat is called for, the water is circulated from the top of the tanks. The top will be hotter due to stratification.Curious as to what you have found is required for tank size and insulation to make it worthwhile to do this?
With a gasification boiler that is properly engineered and designed, the fire is a batch burn. Hot, hard and fast. The heat is transferred away fast to the thermal storage. The wood is loaded to bring the tank temp up to 180°F (80°C) and the fire should burn out shortly after if you did it right. The heating system runs off the...That's pretty fancy right there... kind of up there with a sand battery and/or giant flywheel.
Keep us posted on how it works.
Right now I just use a traditional wood stove... the kids like that the living room is 78 degrees when its 40 and rainy outside.
Installation costs are much greater with hydronic..
Why does most of the world use mini splits in residential?
I would rather leak gas than liquid.Mini-splits mean running refrigerant into the house which has lots of extra connections. (leak potential) 350psi vs 20psi for hydronic?
Wall units are no bigger than base board or radiators. Ceiling cassettes are good but pricy.Mini-splits make you install a gargantuan internal evap unit on the wall, unless in the rare case you have room to install an above-ceiling unit.
One could argue redundancy. Multiple heads off one compressor are OK, but again expensive.Mini-splits in most cases are one outdoor unit and one indoor unit for each zone.
I guess we have something close, a hybrid water heater.Mini-splits can not heat DHW
They are now using R32, best of both R410 and R32Mini-splits can't use the most advanced refrigerant (R-290)
When you say "most of the world", you must mean the US.If hydronic has been used in commercial for decades why haven't it transitioned into residential?
I run my own crews, and do not put a cementitious layer over the tubing. My costs are much less and the thermal response is quicker, however the advantage of hydronic air handlers (cool in Summer) became apparent so that's what I use now.Installation costs are much greater with hydronic.
Why, yes.I guess @quantum` left out that part.
Here's a question. In the summer can a hydronic heat pump create hot water as well as cool the house?
We all make our own choices. My goal is to present a highly viable alternative. In my opinion, more information is better than less. Some do not agree.I would rather leak gas than liquid.
Air to air mini-splits have been used around the world for years, just now the USA catching up.
Using water as a conveyance of energy is used by the rest of the world, Bubba.
R-410 has a GWP of 2,088, higher than that of R-22. R-32 has a GWP of more than 600, whereas R-290 has a GWP of 0.072, and as it is much more efficient than older refrigerants, the compressor and fan can be downsized! R-290 is simply the most advanced refrigerant in use today.
what flushing does is remove all that old crude from the liquid and the scales on the anodes .... yes shocking it alone probably shakes off some of the stuff -- but you would be surprised how much gunk and junk comes out of these batteries ....That sounds like work. I have a success rate better than 50% by just using the welder. No need to play with acid or flush the cells.
I have found there is some loss of capacity on starting batteries. Same as deep cycle that have had EQ charge done often. This is due to some loss of the lead plate. At some point, it is possible the damage to the lead plates from sulfation, then blowing the hard sulfation off the plate will create a weak spot sometimes high up on the plate, eventually that can break off. This can lead to a battery that self drains or has severely reduced capacity.
I've been running a recycled battery in my Honda Accord for 3 years but in cold weather it does not have the CCA it had new. I don't drive that car in winter due to road salt but do start it now and then in the shed. I've had other recycled batteries last a year or two before complete failure. My biggest problem is time. Each battery will kill over an hour as it gets cycled 5 times using the welder with the wait in between. I use 10 minutes cool down as the batteries will get hot.
What do you do with the acid and crud? Seems like an expensive disposal. If done responsibly.what flushing does is remove all that old crude from the liquid and the scales on the anodes .... yes shocking it alone probably shakes off some of the stuff -- but you would be surprised how much gunk and junk comes out of these batteries ....
You must have been a fan of the TV show "Last man on Earth".View attachment 288720
Thanks for closing the loop. You have a spectacularly beautiful spot. I guarantee that one day you'll really appreciate the stupid heater that the lender required.The reliable battery bank with added capacity also won't be lost on you when there are a few cloudy days and you realize that your battery anxiety has floated away.
Sir, I take umbrage to that!Things are working out in fine fashion. As for tv shows, they’re battery acid for the soul.
I have yet to meet a person whose accomplishments were greater by reading library books than watching TV.Reminds me of that sheriff's deputy who put down his shotgun butt down and set his elbow on top. Blew his arm off and he had rags of skin on that arm and his other hand was dangling loose. He was SURPRISED! He sheepishly followed another deputy, presumably to the hospital.
On most TV shows, waste of your life.
Read.
Use it, or lose it.
