Jollysingle
DIYers,
I bought two battery packs connecting parallels in 4/0 DLO cable from Alibaba for $1,350 each, including 16 cells, a BMS, and a stand case, batteries come with fully assembly.
They told me that the batteries are EVE 314Ah MB31 Grade A, but after using them for a month, the charge jumps from 93% to 100% within minutes. When I checked the battery cell voltage at full charge, it was only about 3.4V (see the picture below), which is different from the specifications of the EVE 314Ah MB31.
Since the batteries came pre-packaged, I do not want to open them unless necessary.
Could you please provide guidance or input on what might be causing this issue?
Thanks.
Thanks.
