kolek
village idiot
- Sep 29, 2021
- 280
About to order solar panels and I cannot afford to make a mistake.
Please double check this is a decent reasonable choice for my inverter.
Inverter: Deye SUN-8K-SG01LP1-US
Max PV watts is 10,500 watts
Max input voltage is 500V
Solar panel I'm considering is this HALF-CUT 455 watt panel: Longi LR4-72HPH-455M (quantity: 18)
Maximum Power Voltage(Vmpp) for these panels is: 41.7V
Questions:
1. Will these solar panels work with this inverter?
2. I was planning on hooking them up 9S2P, so each string will be 375V (less than the 500V max on the inverter), good choice? And total watts for all the panels will be 8190 watts which is less than the 10,500 watt max for the inverter. (Unfortunately I have a 200 yard cable "home" run back to my house from the only sunny area I can put these).
3. Is there any disadvantage to the half-cut panels I'm overlooking? For example, do they require twice as many connections/cables per panel as regular panels?
Thanks everyone in advance for reviewing this!
Monocrystalline solar panel 455W LR4-72HPH-455M | DMM エナジー
Technical Datas Module Type:LR4-72HPH-455M Maximum Power (Pmax):455W Open-circui...
energy.dmm.com
Questions:
