I'm running 3 DC strings from the house roof and 1 DC string from the exterior garage to the inverter at ground level. I cannot combine any of the strings because the Amps exceed specs. So, my question is whether or not I need and am required to run my strings into some kind of fused/breaker box before going into the inverter? And since I cannot combine strings, why would the box have to go on the roof? Couldn't it go next to the inverter at ground level or is that not allowed?
Also, I'm going to be grounding the rails with #6 bare copper wire that will run to its own grounding rod. (All panels will then be grounded due to the web fasteners.) Would it be ok to attach a green braded grounding wire to that copper wire on the roof and run it in the same metal conduit to the inverter, grounding the case and grounding bar? Is it wrong to run a bare wire with the DC cables in metal conduit to the inverter?
