Am i safe and do i have everything i need?
rodd95
oklahoma
Hello! I appreciate your time if you stop by to read this and help me out.
Currently investing in a solar system for a small cabin and some tools and wanting to make sure my combination is safe, passes general recommendation, and is everything i need is on my shopping list before i buy.. If i missed anything to ensure this is an entirely safe system please let me know.
The List in its entirety is as follows:
  • 14x 450 watt monocrystalline Perc Solar Panels (6300 watts) link
  • EG4 6000xp off-grid inverter, 8000 pv input, 6000w output, 480v VOC input, 48v 120/240 split phase link
  • 2x EG4 LifePower 4 V2 Lithium Battery, 48v 100AH, server rack battery UL1973, UL9540A link
  • EG4 LifePower 4 communications hub link
  • solar PV DC Quick disconnect switch, solar array dc disconnect switch 1500 Volt 32amp link
  • 4x EG4 Bright mount solar panel ground mount kid, 4 panel, adjustable angel link
Thanks again for your time, and any information and recommendations!
Sounds like the big parts, the little things are going to add it .. PV wire, PV Connectors, things to connect AC up to existing break box (if you have one) … and all the tools to gets things up and running… I’m sure there will be others that can add to the list I started …
Sounds like you’re off to a good start, my system as you can see below is very close, and I am very happy …
Check out this list... Someone else just found listed all the extra stuff.. He did all the work..
Thanks for all your work Matt! Appreciate you vetting everything & giving me some knowledge
