wasteland wanderer
- Apr 29, 2022
- 18
I have a 1998 freightliner retired ambulance that im converting to an overlanded camper build i decided i want to go with a
EG4 6.5kW Off-Grid Inverter | 6500EX-48 | 6500W Output | 8000W PV Input | 500V VOC Input | UL 1741 Certified | All in One Solar Inverter and x2
EG4-LifePower4 Lithium Battery | 48V 100AH | Server Rack Battery | UL 1973 Listed.
Currently looking at this solar panel but am unsure if it will be the perfect fit and compatible with my system which lies my question, will this work good with this system setup? solar panels
what I'm trying to accomplish is max watt per panel with a per panel dimension around 40x 80.
Also would like a constant 4 panel hookup with a simple plug and go ground system, aka extra panels I carry around. Is this possible and how would i go around doing this?
For me paint works very well so i made a little diagram of how i think i can get this to work, just need some guidance.
I also am unsure of steping down 48v to 12v system but i was told this
Powermax WFCO WF8955PECB Black 55A Replacement Power Center (PPC 55A) would work. or is there somthing similar but better?
eventually I may want to add another 2 batteries but the connectors would be different lengths as the first 2 batteries will this be an issue?
I also will eventually be wanting to set up alternator charging. To my knowledge i need a dc to dc charge and make sure alternator is big enough. i plan to do a separate alternator all together just for these batteries. Any link to a dc to dc charger and how to hook this up to this system would be great.
I am an information sponge and am ready to buy ASAP b4 things start to become hard to find.
