GeneHgeorgia
I am looking into buying a couple of these Amensolar N3H-x10us to replace my 3 month old Growatt SPH1000 that I can't get help with. The Amensolar lists it's ratings at 15K PV, but it has 4 array inputs. I have a concern about the 10k. On Watts247, it was listed that the max. per MPPT was 4000 watts. This maybe a problem for me. My PV arrays are 3 at 5000 each. I see the max. input voltage is 500 volts. The manual says something about the MPPT input range max is 440 with batteries. I am only looking to install three arrays. These arrays are mounted and running, is to hard to rewire. The max amp per input is 14 amps. My array output is 13.41 (Imp)
This is what I have. my panels are Vmp = 31.7 X 12 panels = 380.40 v
Voc = 38.3 = 459.60 v
Imp = 13.41 = 13.41 a
My panels are GSD7S54T-425WT
I have read that if you do not exceed the voltage and amperage inputs of each input on a array, you would be good. Also I would like anyone's opinion on this make of a inverter.
Thanks
Thanks
