TommySr
Shame the bms - diy cases are so expensive and take so long to ship. The raw lifepo cells are cheap. ~14.4 - ~15k worth of batteries. Free shipping for USA stocked cells.thinking if you buy a premade battery box $545 it makes the chin/DC house price look sweet
me I'm thinking cheap and thinking cell count.
71kWh?48kwh I've seen an image of unicorn
D71, it can't run my AC or electric dryer trips out invertersplit phase inverter holding up?
agtcovert, is it possible to give us a peek inside one of your battery packs ? crap, now I'm a peeping tom71kWh?
Sure. First pic is before I had the cases and just custom built on a shelf to get going. Others are from when I got a case.agtcovert, is it possible to give us a peek inside one of your battery packs ? crap, now I'm a peeping tom
Not enough. I started using the system about 2 months ago, it was built (by me) around August/September. I have 1 8s2p set of 325Wp panels, a 9s string of 325Wp, and 6s2p 250Wp. I still need to get some proper mounts for some of them, so they're not optimal and need to be changed to be more effective. But it's 14F here this morning, so...probably not this week.agtcovert, how many watts of panels do you have to maintain that size pack ?
how much did all those cutting boards and extra plastic run you, (for each 280 or 305 packs)?Not enough. I started using the system about 2 months ago, it was built (by me) around August/September. I have 1 8s2p set of 325Wp panels, a 9s string of 325Wp, and 6s2p 250Wp. I still need to get some proper mounts for some of them, so they're not optimal and need to be changed to be more effective. But it's 14F here this morning, so...probably not this week.
I just placed an order for 31 405Wp I'll install next year. That should get me closer. I'm hedging on prices going up, so I'll store those panels until spring, after checking for shipping issues.
I currently offset with solar and charge when it's cheap and then run on battery all day. I usually hit charge time with 40-50% capacity. Still saving some money for me, but next year should get me a lot closer to where I want to be.
It's all part of the case kit. Each case has the hardware, PCBs, bus bars, BMS, etc. Each case was around $600 shipped.how much did all those cutting boards and extra plastic run you, (for each 280 or 305 packs)?
I'm using the cutting boards, frugal fucker I am...how much did all those cutting boards and extra plastic run you, (for each 280 or 305 packs)?
I was trying to ballpark what a diy pack of my Winston’s cost against what it costs to safely diy the aluminum cases cells. With Winston’s none of that is needed as they are nylon casedIt's all part of the case kit. Each case has the hardware, PCBs, bus bars, BMS, etc. Each case was around $600 shipped.
Hopefully answering what you're asking.
Damn what did I miss*edit my bad
Tommy how much does one of your home built 24 volt battery packs cost and are you running a bms on them?42OhmsPA, I talked out of turn, you corrected ken about the cutting boards, while I was typing
letting him know it was your battery build that used them not agtcovert's
but I'd like to ask ken what make the winston batteries worth what seems like a premium price ? other then the hard case.
ken do you have images of your battery build that you could share ?
i thought my battery pack photos were in my build thread, but on a quick look they got lost in the reshuffle of my threads when the Admins helped me consolidate them. got to dig around to find more but here are a fewbut I'd like to ask ken what make the winston batteries worth what seems like a premium price ? other then the hard case.
