Ammeters and diodes
Short_Shot
Photon Sorcerer
Do I really have to draw you a picture?
Yes.
Wiring diagrams are of critical importance for understanding wiring... configurations.
Short_Shot
Photon Sorcerer
The solar/AC charger/inverter is an all-in-one...
Sucks to suck then.
Not much you can do about it lol
For a person who's seemingly absolutely confident that it can be done you sure don't seem to be capable of doing it.
You're trying to extract information from the circuit that's simply not there without some programming, a second meter on your load, and a custom digital controller making some assumptions to drive two analog displays.
Either power is going into the battery from the all in one, OR it's coming out of the battery into the all in one. You can't have both at once.
You don't have some magical two way power flow in that wire so how do you intend to pull out two different pieces of data?
Your solution is the two way meter.
OR.
You can simply use the all in one's display whether you like it or not.
That also means your diagram above is meaningless since your setup can't support it.
Short_Shot
Photon Sorcerer
I truly understand the appeal of the analog meter.
I hate digital speedometer on my motorcycles and cars.
It's faster to get an idea of the situation from across the room just by seeing the angle of the needle.
However the information you want is combined together and inseparable once they're both on the same wire. This is why a two way meter like the blue sea or a shunt works the way it does.
You're either charging the battery or drawing from it. Anything occurring after the fact, like simultaneously running a load and charging current from PV, will simply sum together into current in one direction or the other.
Don B. Cilly
Energetic energy padawan
Well, the diode should work. Even the parallel shunt might.
I'll just try... otherwise I'll use another charge controller and separate the wires, I guess :·/
I really do want separate (analog) meters for charge and discharge.
I'm glad you appreciate the beauty of analog. If you have a wind generator... it's priceless :·)
Bud Martin
Photon Sorcerer
The load is not the power source so it cannot make the meter feeding the load to go backward due to no back current flow!
The load PULLS current from Power Source, it DOES NOT PUSH current back to the Power Source.
Bud Martin
Photon Sorcerer
I guess if you really don't want to understand... you won't :·/
It's not that difficult, though.
I do not think you understand how current flow if your look at your schematic to see how the current flows through the Amp meter connected to the load, I am not the only that's trying to explain to you how it works so far.
BTW, my system is also all in one!
Don B. Cilly
Yeah right. You try it then. Show me a load meter that doesn't go backwards when charging without a diode.
Bud Martin
Photon Sorcerer
Well, look at the diagram of your own drawing again, why would the Amp meter connected to the LOAD read backward? You think by putting in the diode as you show will stop the Amp meter on the LOAD for going backward? Like I said, Load does not PUSH the current back to the Power Source!
Look at the current flow in your diagram of what you are trying do.
