Currently using a Renogy Rover Li - 30A paired with Renogy Gel Batteries and I felt like it was time for an upgrade.
Currently have a Ampere Time 12v 100AH heading my way but I’m a little confused on the settings.
Does anyone have this combination? Is it good enough to just switch the battery type in the controller from Gel to Lithium. I emailed Renogy and they gave me a canned reply saying the default lithium setting is only for Renogy Lithium.
So those are the voltages if I stick to regular LI mode without modulations.
I asked Ampere time and they sent me this reply.
Thank you for your message.
For your reference, we've listed the voltage settings for the inverter/controller in our latest product manual.
CHARGING
Charge /Bulk /Boost Voltage: 14.4V / 14.6V
Absorption Voltage: 14.4V / 14.6V
Over Voltage Disconnect: 15V
Over Voltage Reconnect: 14.2V
DISCHARGING
Under Voltage Warning: 11.6V
Under Voltage Recover: 12V
Low Voltage Disconnect: 10.8V
Low Voltage Reconnect: 12.4V
If you have any other questions, pls feel free to contact us.
Best wishes,
Your friend Lynch
From Ampere Time
Would I be okay with just using the stock LI setting with this battery or would I need to make a custom profile under the USER own settings option.
CHARGING
DISCHARGING
Best wishes,
Your friend Lynch
From Ampere Time
