The batteries arrived today on time per FedEx. The batteries were packaged well, although one box was open a little on the bottom. No damage, and they look great. I tested for a charge, and they are both at a stand voltage of 13.2V. The battery cases are a very strong ABS plastic, and I actually got up on one and stood on it. It didn't bend or bulge at all. The cases also have two rope handles that slide out of the way when not in use. They make carrying the batteries very easy. The terminals are very strong and have colored epoxy around each terminal for added strength.
I immediately tried charging them at delivery. Our temperatures here have been below 25 for 3 days, and today is around 19 degrees. So I assume that the batteries were below freezing. One battery started charging, then after about 10 seconds the BMS must have shut down as the charging voltage stopped. The second battery continued to charge even after 3 minutes. I then broke off charging, and put the batteries inside to warm up for at least 24 hours. I will see if the BMS resets on the one battery tomorrow. I will update again as I continue my tests.
Ampere Time included a corporate brochure, a letter of thanks to the customer, extra terminal bolts, a very nice user manual that is very professionally printed on high quality paper stock. The printed material is very well written and very professional. It looks like it was written by someone who has control of the English language. I like it so far. See the pics from unpackaging below.
