Trying to understand the lack of low temp sensor for my application. I run a boat with an electric motor in 36v configuration. The use case is often in very cold water (Michigan and fishing this time of year). We fish right up until the lakes freeze over. Often times fishing in air temps below freezing. Could I use the Amphere time 12v 100ah batts wired in series for 36v as long as I stayed above freezing for charging? I keep this boat in a heated garage and would wait until home before charging. Thanks for any insight.
