I have a 24v offgrid system and I want to add a fuse between the battery and the 3000w inverter. I use 4/0 wire. Most people cut the wire and introduce the ANL fuse in the middle of the wire. Shouldn’t it be ok to just add the ANL fuse at the end of the wire and connect the ANL to inverter? Or is this a bad idea? If so… why.
