FreedomFighter1
- Jul 26, 2020
- 13
Did you solve this issue with your set up? I believe I built the same set up 24V 2000W system. My 2000W- 4000W PURE SINE continuously beeps with TWO (12V 100Ah) series connected. However if I just use ONE ( 12V 100Ah ) Battery is works fine and has not beeps. If it is to high of a voltage with TWO is there a way to lower it a bit with an add on? I seem to follow the design not sure why I am getting a high input Protect light and beep. Any help would be great.
