dielectric
- Dec 5, 2022
- 58
It would. The stud would be in contact with the battery and the tig can point the arc in the right direction. I'm also just a hobbe/occasional tig welder but the setup would melt both pieces.I think it would work. With the negative lead attached to the stud and the stud making contact with the cell terminal you're OK.
On my welding table, the negative lead is attached to the table, not the piece I'm welding. That's good enough.
The 160$ question is would it melt them too much.
I have 4 out of 16 cells with detached studs, should probably get a refund... The capacity is great, the application is stationary... But I don't want yet another adventure trying to weld these myself.
3 spots around should be good enough for mechanical strength and electrical conductivity but the flat contact surface may get warped and then it's really a problem.
In the other hand if I tacked on a piece of aluminum angle and could use a bus bars in a vertical plane with as much torque as I want...
I've not decided.
