Q-Dog
¯\_(ツ)_/¯
I bought my batteries before I found this forum based solely on the capacity I needed to run my fridge and the fact they were in the US. If I had found the forum first I would probably still be trying to decide what to get. I'd probably also still be waiting on cells to ship from china.
My cells came with a couple of long zip ties and a small roll of double sided squishy tape to stick between them. I thought the foam was an odd choice until I saw the cells beginning to swell and the pack got over 1/4" wider the first time I charged them up. I want to add capacity down the road so may have to reconfigure and I didn't want to damage the cells trying to pull them apart, so I instead slipped some 1mm thick foam sheets between my cells. I cut the foam from some packing envelopes that got away from someone and floated into my yard after a thunderstorm. I cut them a little bit long and used slits in the tops to keep the bms wires organized. After seeing a couple of drop-in LiFePo4 battery teardown and reading a couple of posts here on the forum I modified my cell holder to fit snug around the cells and constrain them, and I haven't noticed the pack moving any more. These are 200ah cells. I imagine the larger cells expand more.
Also, before I found the foam envelopes in the yard, I was going to experiment with paperboard or cardboard or construction paper between the cells to allow them to move a little bit. I was also considering something like felt or fiberglass matt, anything to let them flex a little bit but remain constrained.
